Re: Re: Re: Re: F-20 sleeves/pistons
Posted by Farmall Gray on September 23, 2001 at 16:37:13 from (152.163.207.56):
In Reply to: Re: Re: Re: F-20 sleeves/pistons posted by WIRED on September 20, 2001 at 19:42:05:
This is just a thought, but would you consider using used sleeves and pistons? You can probably
find decent ones fairly cheap. Most stuck engines only have one piston that is stuck and the rest are usually ok. That is the case with my F-14.
I'm going to find one good used sleeve and piston and put it back together with new rings.
Post A Followup
: Re: Re: Re: Re: Re: F-20 sleeves/pistons
