Re: Will a C-153 fit in an A
Posted by big diesel on September 23, 2001 at 17:21:09 from (152.163.201.193):
In Reply to: Will a C-153 fit in an A posted by redhead on September 22, 2001 at 19:24:05:
the engine will fit, but the crankshaft on the combine engine was never drilled for a pilot bearing.........
Post A Followup
: Re: Re: Will a C-153 fit in an A
