Re: Re: Re: cracked rear end in Farmall M
Posted by justin on September 24, 2001 at 15:34:10 from (209.23.129.4):
In Reply to: Re: Re: cracked rear end in Farmall M posted by The Red on September 24, 2001 at 09:35:52:
What the welder did, was V out and chase the crack about 1" past where it ended, and braze the crack shut. The V was twice the thickness of the original cast iron. When you mean both sides, I assume you mean for the right and left bull gear? if so, yes.. If you are meaning the outside and inside of the casting, NO.. there is no nead to braze both sides. brazing is like soldering, the braze will flow and bond to the heated areas.
Post A Followup
: Re: Re: Re: Re: cracked rear end in Farmall M
