Farmall Tractors Discussion Board
Re: Re: Re: Re: Re: 1951 Farmall H Sleeve Removal
Posted by mj delaney on March 04, 1999 at 09:58:30:
In Reply to: Re: Re: Re: Re: 1951 Farmall H Sleeve Removal posted by The Red on March 04, 1999 at 06:06:10:
Only thing I ever noticed is grey paint(babbitt?) in the bottom of the oil filter housing. Always wondered what that small screw in the oil filter base was for. Now I know... you can wash that old crud out of there.
Post a Followup
: Re: Re: Re: Re: Re: Re: 1951 Farmall H Sleeve Removal
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
