Re: Re: Super C.... Fouling Plugs
Posted by Jere Hummelgaard on September 25, 2001 at 03:03:05 from (12.64.24.63):
In Reply to: Re: Super C.... Fouling Plugs posted by Les Repair on September 24, 2001 at 17:57:28:
My Dad's Super C had the same problem. Hydraulic fluid was also disapearing. He gained oil in the crankcase (A LOT)! The seal on the gear shaft of the hydraulic pump was leaking, the crankcase would over fill by as much as 1 gallon and build up pressure enough to blow hydraulic fluid past the piston rings (weak rings) and foul the plugs. I replaced the seal and all the problems including the fouling plugs have gone away.
Post A Followup
: Re: Re: Re: Super C.... Fouling Plugs
