Re: Ironguard paint and a manifold mystery
Posted by Farmall Gray on September 25, 2001 at 07:41:50 from (152.163.201.67):
In Reply to: Ironguard paint and a manifold mystery posted by BTD on September 24, 2001 at 04:18:42:
Some paints are more durable than others, But I don't think any paint will totally resist gas constanly dripping on it. I painted my F-12 about 10 yrs ago with urethane paint. Over the years, the sediment bowl leaked a few times and it stained the paint on drive coupling cover. It didn't wrinkle it off though. This was very expensive paint-about $125.00 a gallon. The best thing to do is to fix the leaks so that the gas doesn't drip on the paint. All of the operators manuals that I have read on these old tractors recommend that you shut off the gas when the tractor is not in use. I have gotten in to the habit of shutting the gas off it it going to sit for more than an hour on all of my tractors. Some times sediment bowls will leak when the gas is on. This is bad. They can be fixed so that they don't leak. I have had good success with repaking the valves with graphite faucet packing. Do not use teflon packing. I use rubber bowl gaskets and they still have to be replaced every once in a while. As for carb leaks, most will occur when the tractor is sitting with the gas turned on and the engine not running. They will drip if you over choke it. they are supposed to do this so that the gas doesn't build up in the bottom of the carb. The Farmall regular had a little drip pan under the carb that let the gas run out past the frame rail to the ground. You could make something like this out of a plastic jug. Maybe you could even find a red jug or oil bottle that wouldn't look so obvious. On my Dad's one tractor, He drilled the weep hole out on the carb and put in a brass elbow and a piece of copper tubing so that what leaked out dripped on the ground. This may not be a good idea if the tractor is run in a lot of dust because it would draw unfilterd air in through the tubing.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
