Re: Renewing threads in M axle carriers?
Posted by The Dukester on September 25, 2001 at 17:49:52 from (216.93.119.8):
In Reply to: Renewing threads in M axle carriers? posted by Lowell Davis on September 25, 2001 at 16:09:31:
Those axle housings are cast iron I think, so you could just drill out the holes to the next minor diameter size for the next larger s.a.e. coarse size and tap them out, make some new spacer bushings, enlarge the holes in the fender extensions, get new capscrews(bolts) and lockwashers and you've got a new, oversize, stronger mounting. Check them old holes over closely, there might be enough "meat" still left there, chase the threads with a 1/2-13 bottom tap.
Post A Followup
: Re: Re: Renewing threads in M axle carriers?
