Re: H paint
Posted by Michael Soldan on September 25, 2001 at 19:05:06 from (216.46.140.186):
In Reply to: H paint posted by Evan on September 25, 2001 at 18:13:29:
Evan, I agree with other comments, I am anti-sandblast and believe in degreasers and pressure washers. Oven cleaner works well on heavy baked on grease around the manifold...then wirewheel and sand paper. I also believe primer is cheap and two good coats of primer( rub with fine paper in between) and a coat and a wet coat will give you a good job. Good luck from Mike in Exeter Ontario
Post A Followup
: Re: Re: H paint
