Re: Re: Kinda off the subject, but need advice on an air compressor..
Posted by gene b on September 26, 2001 at 02:49:00 from (63.15.137.196):
In Reply to: Re: Kinda off the subject, but need advice on an air compressor.. posted by Denny Frisk on September 25, 2001 at 10:17:44:
do you have your sand blaster yet I have a portable 75cfm set at 8olbs run a 3/16 nozzle works fine also have a small 40lb pressurized got from HARBOUR FREIGHT use a 1/8 nozzle with 80psi reg great for the small stuff cause it will run ok on the shop compressor get one with around 11cfm@90 psi check around they run on 220 should find one for around 400 or so bigger one would be better but better decide what you are going to have for a sand blaster
Post A Followup
: Re: Re: Re: Kinda off the subject, but need advice on an air compressor..
