Re: M Clutch
Posted by Phil Auten (Tx) on September 27, 2001 at 09:31:06 from (63.173.243.163):
In Reply to: M Clutch posted by Dave on September 27, 2001 at 06:54:29:
Dave,
If you mean that the clutch will not release, it's probably rusted to the flywheel. This is a fairly common problem with almost all tractors that have a dry engine clutch.
One solution is to start the tractor in gear and drive it around while stomping the brakes with the clutch pedal locked down. Sometimes it takes a while to get the clutch unstuck, but this usually works. It also helps if there is a load on the tractor like a brush hog or even a plow.
If that doesen't work, you might try some kind of pry bar through the belly pump mounting hole (of course, the pump will have to be removed first).
Phil
Post A Followup
: Re: Re: M Clutch
Today's Featured Article - Product Review: Kreem Brand Fuel Tank Liner - by Staff. This condition has occurred on a few machines that we have had and fortunately we were able to borrow the technique used at the local motorcycle shop. The product that we have used is called Kreem thouh there are others on the market, this one was recommended and available. This particular product is sold in three parts, a bottle of etch, dryer, and sealer. We were fortunate enough to start the process with stern warnings from those that had used this type of product before. The horror ... [Read Article]
