Re: Farmall Cub governor adjustment?
Posted by dnoha on September 28, 2001 at 06:46:31 from (205.245.122.225):
In Reply to: Farmall Cub governor adjustment? posted by one - L Darrel on September 27, 2001 at 21:43:37:
Darrel (with 1 "L") My '49 Cub governor was acting similar to what you describe. I traced the problem to the shaft that goes from the governor on the right side of the tractor and across the front of the engine to the throttle linkage on the left side of the tractor. Where this shaft was inserted into the governor, it had a lot of play. Thus I could advance the operator lever and the governor would respond, but the shaft might or might not turn, thus the throttle didn't always respond. I removed the shaft (just pulls out). There's a little key at the top of it and the key was fine but the shaft was worn down at the bottom. I don't have welding equipment to build it back up, so I broke off a little piece of a hack saw blade, curved it a little and shoved it into the bottom of the opening the shaft slides into. Then reinserted the shaft, tapped it lightly with a hammer to seat it fully and the free play was gone. Now the throttle responds properly to the governor. After fixing the governor, I followed the specs in my manual for setting the linkages in question. Now when I advance the operator speed lever all the way forward to the last tooth, the RPM's are much lower than they were before. However, since the governor is now reliably doing its job, this lower RPM seems sufficient. When I hit tall grass, it pours on the gas and gets the job done. Before fixing the governor, I suspect the previous owner had set the linkages up to deliver a higher than appropriate RPM to get through tall grass. Don't know if I have it right, but it sure is quieter than it was and seems better for the tractor. Mows grass/brush just as thick or tall as before, but only throttles up when it actually needs to.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
