Re: loose steering
Posted by J3nut on September 29, 2001 at 17:46:56 from (64.12.107.51):
In Reply to: loose steering posted by max on September 29, 2001 at 12:58:54:
I have a Super C with the same problem.
A friend suggested I try this but I have not gotten that far yet.
If the gear that meshes with the worm gear is worn bad, take it off, turn it 180 degrees and put if back on. That will put the worn teeth on the side that does not get used much and good teeth on the side that does get used. He has done this on an M with good results.
Let us know what you find and how it works, I will be working on the steering this winter.
Post A Followup
: Re: Re: loose steering
