Re: PU 15-30 Stationery Engine
Posted by Dick (IL) on September 30, 2001 at 07:06:10 from (152.163.207.59):
In Reply to: PU 15-30 Stationery Engine posted by Milton Fox on September 29, 2001 at 09:56:04:
Back in 1980 or so I bought a power unit from an old IHC mechanic and collector. The engine was the same as that found in a 22-36 tractor. I needed a block for the 22-36 I was working on at the time, and one that had been under flood waters many times. Though I had to remove the power unit clutch housing and replace it with the tractor's rear housing, eveything else, if I remember correctly bolted in. The original manifold had been replaced with a "cold" gasoline manifold. Sorry, I can't remember anything about the serial number off the power unit.
Post A Followup
: Re: Re: PU 15-30 Stationery Engine
