Re: int 454
Posted by David on September 30, 2001 at 13:23:39 from (24.3.0.34):
In Reply to: int 454 posted by peterc on September 28, 2001 at 17:24:04:
Try calling Duvall in Frederick,Maryland 1-800-423-4032. I have a 2400A which is the industrial version of the 454. They have been photocopying the pages from their 454 service caralog to help me put ine back together, after I had to rebuild the head---previous owner didn't replace bad radiator core; found out it had overheated many times. Head was badly warped, with gasket blown between ALL Cylinders.
By the way, I found it impossible to locate a radiator or core--my local shop is having it custom made for under $300. Let me know if you need their number.
Post A Followup
: Re: Re: int 454
