Re: Re: Diesel Knocking
Posted by zeus on October 01, 2001 at 09:47:53 from (152.163.204.64):
In Reply to: Re: Diesel Knocking posted by big al on October 01, 2001 at 07:25:35:
In addition to what Big Al proposes, I suggest that you check to see if air has entered the fuel system; if so, bleed system. Also check the fuel injection timing; and make sure the fuel you are using is of good quality, the correct cetane rating, and not contaminated.
In other words, check the simple things first before you shell out the big bucks for an engine overhaul which probably is not needed.
Post A Followup
: Re: Re: Re: Diesel Knocking
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
