Re: HELP!!! Leaking PTO seal on Farmall B
Posted by Dave T on October 02, 2001 at 13:46:54 from (63.27.107.232):
In Reply to: HELP!!! Leaking PTO seal on Farmall B posted by Will on October 02, 2001 at 12:32:54:
Takes a little time, but it's not hard. Seals you can find anywhere...it takes a nice brass punch to tap shaft out of casting. Getting it back together can be a nightmare, but if done right, it's not too bad. On reassembly to tractor, hang the housing on the two studs just a short ways. This will allow you to correctly place the pto lever in proper groove. Now slide on belt pulley housing and slide both onto studs and bolt on...Of course you want to make new gaskets too...
Post A Followup
: Re: Re: HELP!!! Leaking PTO seal on Farmall B
