Farmall Cub axle:What am I doing wrong?
Posted by mark on October 02, 2001 at 15:30:57 from (205.188.197.153):
Hi Folks...I need some help..I am trying to take the front axle off of a Farmall Cub so I can get at the steering gear box to replace all seals, gaskets, etc....I took off the 2 bolts holding the axle pivot shaft pin in, but I can't get the shaft to come out..is there a snap ring or something in there that I'm missing?..is there a certain way it comes out..forwards or backwards?..anything you tell me will be a help at this point...thanks!
Post A Followup
: Re: Farmall Cub axle:What am I doing wrong?
