Supporting Farmall A with engine off.
Posted by Brian on October 02, 2001 at 20:25:52 from (24.101.171.230):
I am planning to remove the front end and engine from my tractor. I know that the best way to support the tractor is to "mount" stands to the sides of the transmission housing... however, it would be easier if I could just support it using blocks/wood under the flat spot on the underside of the transmission.
Will i run the risk of cracking the housing if I do this ? Can it support the weight ?
Thanks.
Post A Followup
: Re: Supporting Farmall A with engine off.
