Re: Stuck Super H fan pulley
Posted by mikew on October 03, 2001 at 14:38:05 from (216.81.145.250):
In Reply to: Stuck Super H fan pulley posted by Bill Jones on October 03, 2001 at 14:14:37:
When I redid my waterpump assembly on my H, my pulley was originally stuck tight also. Infact, the adjusting side of the pully was cracked but it was still stuck tight. I ground out the crack and brazed it back together - still holding today. There is no easy way to solve your problem other than to take the whole assembly off and take it over to the bench and start tearing it down and cleaning out the threads. Be carefull when you beat on the tabs on the side of the pulley that you don't get to carried away as you can crack the pulley also. Simply remove the 4 bolts that mount the whole assembly. You will need a new gasket most likely but it will be about as easy to work on it at the bench and at this point, you can put new packings in the unit while you are at it. In the end, you will be better off. If you go this route, be sure and use at least three of the little packing pieces down in on the center shaft to assure a good seal. After I had it apart, I used a little never-sieze on the pulley threads before I put it back together also. In the end, I was glad I went the extra steps - pulley works great now. In restoring my 45 H, I have come to appreciate much of the designs used in these tractors but this pulley assembly is not one of them. Also - don't over grease it.
Home
| Forums
Today's Featured Article -
Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
