Re: Re: Re: Re: International 240 tractor
Posted by Mark-NC on October 03, 2001 at 20:42:02 from (165.247.137.29):
In Reply to: Re: Re: Re: International 240 tractor posted by Stev e K on October 03, 2001 at 16:06:26:
I'm in the process of doing that exact same thing. I've discovered that the Utilities with power steering have a different gear ratio than ones without. The power steering equipped tractors have 25 teeth on the gear while non-power steering gears have 50 teeth. If you decide you need replacement parts, just be aware.
Has anyone ever had a problem with the worm gear inside the bolster? Mark
Post A Followup
: Re: Re: Re: Re: Re: International 240 tractor
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
