Re: HELP WITH EXHAUST LIFT --FARMALL A
Posted by gene b on October 04, 2001 at 03:41:08 from (65.229.174.166):
In Reply to: HELP WITH EXHAUST LIFT --FARMALL A posted by PETE CORMIER on October 03, 2001 at 16:56:59:
when you pull the lever there should not be any exhaust comong out of the muffler if the cast bowl is old maybe the seat where the flopper seats on needs the surface cleaned i have made a mandrel to do this used my 187-plow the other day and it will pick up the plow at fast idle easy the rubber o-ring in the pressure comtrol if bad will not hold the load will lift ok but not hold the pressure use three of these devices work fine when things are in shape
Post A Followup
: Re: Re: HELP WITH EXHAUST LIFT --FARMALL A
