Re: Build or buy a front blade for Super A
Posted by gene b on October 04, 2001 at 03:55:32 from (65.229.174.166):
In Reply to: Build or buy a front blade for Super A posted by marvin on October 03, 2001 at 08:01:50:
i would build one out of some 11ga not too expensive 80bucks for a 4x8 sheet plenty of material for a blade and brackets to mount with made mine 18 high and 5 wide had it broke two places and then had a piece broke u-shaped like a channel welded on the back for strength used 1/2x2 for a edge works fine use the exhaust lift for raising up next progect is a snow blower
Post A Followup
: Re: Re: Build or buy a front blade for Super A
