Re: Couple Quick Questions
Posted by Denny Frisk on October 04, 2001 at 05:55:43 from (12.4.181.2):
In Reply to: Couple Quick Questions posted by Orion on October 04, 2001 at 01:08:35:
Dad ran Hy-Tran in His '51 M for a couple years. The rearend made more noise or whine when HyTran was in it. Also, It took forever for the gears to finally stop turning so You could shift out of neutral into gear with the Hy-Tran. If Your clutch drags at all, You may never shift without clashing again. As said here, It will seep by seals You though were good. But it is a great lubricant. Dad & I both run 90W in Our Super H & M now. We use Hy-Tran only in the live Hyd. on both.
Post A Followup
: Re: Re: Couple Quick Questions
