Re: super H brakes
Posted by Bob M on October 04, 2001 at 19:09:57 from (66.66.72.246):
In Reply to: super H brakes posted by harlen larson on October 04, 2001 at 18:48:00:
Harlen - You probably need to replace the brake friction disks on both sides. It's a simple job and no special tools are required. You'll need 4 new friction disks to do both brakes.
While you have the brakes off, recommend disassembling the center disk set. Thoroughly clean the balls and the ramps the balls run in. Then lightly dust the balls and ramps with dry graphite lube or similar before reassembling.
Post A Followup
: Re: Re: super H brakes
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
