Re: Help! Super C govenor questions
Posted by gene b on October 05, 2001 at 05:04:55 from (63.42.174.16):
In Reply to: Help! Super C govenor questions posted by Mark Jones on October 04, 2001 at 18:01:29:
sounds lik when you changed the brng you moved the mag gear a few teeth didnt realize what was happening if you take housing off get it on #1 piston compression take spark plug out to make sure you are on compression you will be able to see the dots on the cam and the mag drive gear better get a manual so you know the correct dots
Post A Followup
: Re: Re: Help! Super C govenor questions
