Re: Re: Coolant in Oil
Posted by Andy Martin on October 05, 2001 at 10:36:58 from (63.26.133.197):
In Reply to: Re: Coolant in Oil posted by The Red on October 05, 2001 at 10:29:07:
I agree. Also, retorque before you start it. If you haven't started it already, I'd pull the plugs and spin it to make sure you don't have one or two pistons with water on them.
Then after the hot retorque I bet you'll be OK. I'd hold off on the sealant until I knew whether the retorqueing fixed it.
Around here Bars-Leaks is the sealant of choice. I really like their new tablets.
Post A Followup
: Re: Re: Re: Coolant in Oil
