Re: Coolant in Oil
Posted by Paul tx on October 05, 2001 at 12:57:47 from (207.173.224.6):
In Reply to: Coolant in Oil posted by Jeff on October 05, 2001 at 10:13:32:
Jeff,
Had the same problem you did with my H. I blew a head gaskett so I replaced it and torqued to specs. After a few uses through the field, I shut it down for the night. Next day, oil pan was filled with coolent. Through research, I was told to retorque the head bolts cold put in some bars leak get up to operating temp (30+mins)shut down the engine and retorque. I haven't had a problem yet.
Paul
Post A Followup
: Re: Re: Coolant in Oil
