Re: M - Dripping oil like my sink.
Posted by doug vose on October 05, 2001 at 17:34:22 from (64.30.146.202):
In Reply to: M - Dripping oil like my sink. posted by Sarah on October 05, 2001 at 17:03:18:
dont believe so, because the flywheel needs to be removed to get crank out(its that way in my 300 RC). The easiest way to split a tractor (besides taking it to a mechanic) is to jack the front of the tractor slightly to lift weight off of the front tires, then put a hefty jack stand under the clutch housing, then lower the jack to put the weight on the stand.(at this point i already had the tin, radiator, cyl. head, and manifold off) Then hook somthing op to the steering pedestal, unbolt it, and slowly lower it to the ground out of the way (I accidentaly dropped mine, it didnt brake anything, but it fell right in my way). then, i removed the belly pan and oil pump, and rolled my floor transmission jack under the engine, place a couple of 2by4's on the jack, and jacked it up to get snug against the engine. then remove the frame rails and all engine bolts (i removed the starter too) making sure that all the weight of the enginge is on the jack (or hoist if you have one) and you should be able to slide the engine straight back(forward), make sure that the engine is chained to the jack, however, because mine almost fell atop me. after removing engine, take off the clutch bolts and remove the clutch. then you can take the four flywheel retaining bolts off and remove the flywheel. you then have access to the rear of the crank shaft. if you need to remove the whole crank, please look in a manual, because my fingers are getting tired ;). ps. make sure anything connected to the engine that is connected to any other part of the tractor is removed. What was stated above is the way i went about removing the engine from my 300 RC. I hope ive helped a little
Home
| Forums
Today's Featured Article -
A Cautionary Tale - by Ian Minshull. In the early 1950s my father bought an Allis Chalmers B and I used it for all the row crop work with the mangolds and potatoes, rolling and the haymaking on our farm. The farm and the Allis were sold and I have spent a lifetime working on farms throughout the country. I promised myself that one day I would own an Allis. That time event
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
