Re: Coolant in Oil
Posted by Dave G on October 06, 2001 at 04:55:10 from (158.252.165.11):
In Reply to: Coolant in Oil posted by Jeff on October 05, 2001 at 10:13:32:
I have had that problem with a Farmall B. Like the others say you have to retorque after hot. Make sure you recheck you valve clearance because they will get tighter. Also, I have had to use a sealer on the head gasket. In fact the gasket said " Sealer and Retorque required". I use the coppers spray on and found that works good. Don't give up on the head gasket - I bet thats your problem.
Post A Followup
: Re: Re: Coolant in Oil
