Re: Re: Rust flakes from fuel tank finally out.
Posted by Bob in Southwest Iowa on October 06, 2001 at 13:20:11 from (207.32.13.239):
In Reply to: Re: Rust flakes from fuel tank finally out. posted by Luke Petre on October 06, 2001 at 11:43:07:
Luke,
Like Red said, you can unscrew the sediment bowl assembly and clean out the inlet on top of it. It was always my job as a kid to keep my finger in the tank outlet while my dad cleaned the sediment bowl inlet :)
When everything is back together and sealed up properly, the gas will only drip into the glass at a slow rate. To see the glass fill quickly, unscrew the gas line where it enters the carb so air can escape and the glass bowl will fill quickly. This lets you know that the inlet to the sedimet bowl assembly is clear.
Hope this helps,
Bob
Post A Followup
: Re: Re: Re: Rust flakes from fuel tank finally out.
