Re: Re: Belly Pump on M
Posted by wally on October 08, 2001 at 10:09:34 from (206.72.54.135):
In Reply to: Re: Belly Pump on M posted by Bob Soper on October 07, 2001 at 18:42:41:
make sure that both hoses for the cylinder are in the front ports on both sides of tractor the rear port on the left side as you sit on the m is for delayed lift. you'll do fine it is a good combination.
Post A Followup
: Re: Re: Re: Belly Pump on M
