Re: Re: Re: Tractor buying questions
Posted by Alabama on October 09, 2001 at 17:56:14 from (64.12.102.177):
In Reply to: Re: Re: Tractor buying questions posted by 68 Mag on October 09, 2001 at 14:42:43:
If Your around Alabama, I know of an H (Next smaller than the M) for $1,500 with a set of drag disks...both in good cond. paint bad though. Also a I-4, is much smaller than M but same engine as H...just looks smaller. It's a great tractor(not 3 pt though). Its $1800. Live Hyd. run off the engine instead of trans-pto. If I have this right...Live PTO will work independent of your gears. With my M if I put my cluch in the PTO stops...With newer tractors you can shift gears while and the PTO still turns. It's not a big deal to me cause I can start off in 4th with an engaged PTO without a problem.
Post A Followup
: Re: Re: Re: Re: Tractor buying questions
