Re: H-motor stuck
Posted by Brian on October 09, 2001 at 18:21:06 from (24.101.171.230):
In Reply to: H-motor stuck posted by AGR538 on October 09, 2001 at 11:00:35:
I agree with Red.
Time is needed to let it soak in. It took me 1 year to get mine unstuck after about the same amount of time. I would only use the crank to try and rotate the motor, anything else will increase your chances of breaking something. Also, you MUST take the valve cover off and check the valves to make sure they are free. If you start here up and one is stuck you can add a couple of hundred dollars to your restoration bill.
Don't do anything I wouldn't do.
Post A Followup
: Re: Re: H-motor stuck
