Re: 12 volt farmall-h?
Posted by The Red on October 10, 2001 at 06:50:26 from (206.246.187.2):
In Reply to: 12 volt farmall-h? posted by jim on October 10, 2001 at 06:25:41:
Jim if you want to go the alternator route, punch below for Bob Melville's super wiring diagram. He uses a Delco 10sI alternator.
You can still use the 6 volt coil. All you need is a ballast resistor in the coil line prior to the coil. NAPA part 13 ICR. I mount them up on the steering center support bracket next to where the oil line bolts to the bracket.
Post A Followup
: Re: Re: 12 volt farmall-h?
