Re: 12 volt farmall-h?
Posted by Bob M on October 10, 2001 at 07:25:38 from (165.170.128.66):
In Reply to: 12 volt farmall-h? posted by jim on October 10, 2001 at 06:25:41:
jim - Cheapest way is to continue doing what your are doing - simply run the tractor off a 12 volt battery and recharge it with an external charger as needed. The only change you should make is as Red suggests: Stick a ballast resistor in line with the primary feed to the existing 6 volt coil - it will greatly extend the life of the points and coil. Will also will approximately double your engine run time before you need to recharge the battery. So if you run the tractor infrequently, and you don't forget to charge the battery - especially in freezing weather - this is probably the way to go.
However for a modest expenditure ($50 or so) you can replace the old generator with an alternator. But be aware while squeezing a 10SI alternator under the hood of an H is possible, it's not easy. Some creative metalworking to make a suitable bracket is necessary.
Good luck!
Post A Followup
: Re: Re: 12 volt farmall-h?
