Re: farmall 300
Posted by jmyt_47 on October 10, 2001 at 13:38:15 from (170.92.64.254):
In Reply to: farmall 300 posted by TomT on October 10, 2001 at 12:57:38:
The remote pipes from the control unit are easy to find at the junkyard. It has a special oil seal flat mount. Nothing to rig up temporary, unless you have some flare tools, fittings, and good pipe left. Can you use the forward remote outlets to test instead? (in front of the control unit on the right side) The hydraulic pumps on these tractors are the gear type, so there's not much to rebuild except for a shaft seal or two. If it is shot, it can be replaced for $250 or so for a used one.
Post A Followup
: Re: Re: farmall 300
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
