Re: Re: M wobble Need help!!!!!
Posted by Evan on October 10, 2001 at 14:19:19 from (63.26.161.13):
In Reply to: Re: M wobble Need help!!!!! posted by john d on October 09, 2001 at 22:24:49:
The only thing i haven't replaced is the bearing at the end of the worm gear shaft i've replaced the bottom bushing, bearing felt seal and seal holder. On the top i've replaced that bearing and seal and it still wobbles.
So if i change that bearing it will help a lot??
if not the only thing left is the gear and they look brand new!!!
Thanks for the response i really appreciate it
Evan Shockey
'47 M
'47 H
'49 H
Post A Followup
: Re: Re: Re: M wobble Need help!!!!!
