Re: Farmall 340 No Go ShowBoat
Posted by Don H on October 10, 2001 at 16:02:43 from (205.188.195.27):
In Reply to: Farmall 340 No Go ShowBoat posted by Tim C.(MI) on October 09, 2001 at 18:02:38:
I had a similar problem on my 350. It turned out to be simple. There should be a switch to make the valve single or double acting, and it is located on the back side of the valve housing. It looks like a cotter pin that can be rotated to either of two positions. Mine was stuck in the middle and it did just what you have described. Check the valve and see if you can find it. Hopefully by moving it to one or the other of the positions you will solve your problem. Good luck.
Post A Followup
: Re: Re: Farmall 340 No Go ShowBoat
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
