Re: 130 Belt Pulley Drive Install
Posted by scotty on October 11, 2001 at 06:40:06 from (199.231.49.128):
In Reply to: 130 Belt Pulley Drive Install posted by Scott on October 10, 2001 at 16:40:42:
Scott,
Backlash can be measured in a number of ways
either with feeler guages or with dial indicator.
Backlash is basically the amount of play between
bevel gear and pinion before any actual motion
takes place on the shaft.Red lead or prussian blue
applied to the bevel will indicate what amount contact you have between the gears.Hope this helps.
scotty
Post A Followup
: Re: Re: 130 Belt Pulley Drive Install
