Re: filled tirees
Posted by Alabama on October 11, 2001 at 06:52:29 from (205.174.143.2):
In Reply to: filled tirees posted by busch on October 10, 2001 at 18:36:53:
Im no expert, but here are my thoughts. If you need the extra weight for traction and don't have wheel weights then keep the fluid. I have fluid filled in my 47 M, the rims are orig. with no corrosion. If you don't need the weight and want to get rid of the fluid you may want to do it with a tire change by a tire shop. If you just want to get rid of the fluid you should probably call a tire shop and see what the will charge. Good luck.
Post A Followup
: Re: Re: filled tirees
