Need help with 560 Gas!
Posted by Dan on October 11, 2001 at 13:44:12 from (24.223.17.80):
We have a 560 Gas that has a hydraulic leak in the right rear. I don't know the technical terms but I will try to explain more specifically. It is leaking around the lower bolts that hold what I would call the right rear axle housing to the rear end. It is a constant drip and if you let it sit for a few days it will have leaked out enough that it will lose its power steering. Is this easy to fix? Is there just a gasket between the housing and rear end? where can I get parts?
Thanks,
Dan
Post A Followup
: Re: Need help with 560 Gas!
