Re: international h backfiring at carb in high rpm and no power
Posted by Bob M on October 11, 2001 at 16:25:52 from (66.66.72.246):
In Reply to: international h backfiring at carb in high rpm and no power posted by chuck on October 11, 2001 at 11:33:52:
I agree with Red - sounds like an ignition problem. First check the timing advance with a timing light. Should be right around 0 deg (TDC) at idle, and advance to about 35 deg BTC at full RPM.
If you haven't already done so, replace the plugs with new. Use Champion D-21 or the AC equivalent (C86?). Also replace the points and condenser, and make sure the point gap is correct (0.020) Unless the high voltage wires are solid copper (not radio surpression or "resistor" wires) replace them also.
Post A Followup
: Re: Re: international h backfiring at carb in high rpm and no power
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
