Re: Which Farmalls are alike?
Posted by john d on October 11, 2001 at 19:49:08 from (205.188.192.43):
In Reply to: Which Farmalls are alike? posted by J.D. on October 11, 2001 at 19:41:49:
Generally speaking....if you can hang something on an M, you can put it on a 400 or 450. The 300 and 350 tractors are derivatives of the H line, so they are narrower. The loader brackets will likely match up to the rear axles okay, but you'll probably need spacers - about 1.5" - on each side of the frame rails to make the front fit. A 460 will likely work also; measure the frame-rail width before trying it.
Post A Followup
: Re: Re: Which Farmalls are alike?
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
