Re: Farmall H PTO
Posted by Bleedinred on October 11, 2001 at 21:15:26 from (152.163.201.46):
In Reply to: Farmall H PTO posted by Terry Anderson on October 11, 2001 at 19:05:37:
There's a spring and pin that hold the lever in place, either engaged or not engaged. Back the flat head screw out of the pto housing--it's located near the lever. Could be that the spring is broken or that the pin is worn down so far there isn't enough pressure to do the job. I think you can fish the pin out with a magnet, otherwise you would have to pull the pto shaft/assembly out. That requires taking the shield off and then pulling three bolts. It comes out real easy. Good luck, Wes
Post A Followup
: Re: Re: Farmall H PTO
