Re: Re: Needing F30 advise.
Posted by Dick (IL) on October 13, 2001 at 07:12:21 from (205.188.197.156):
In Reply to: Re: Needing F30 advise. posted by Dale13 on October 13, 2001 at 05:06:34:
I don't think you need a ring compressor to install pistons in the old IHC engines from the bottom. The sleeves have a chamfer that allows you to start the rings in the bore. A little pressure upwards and the whole piston assembly slips right in. Always worked for me.
Post A Followup
: Re: Re: Re: Needing F30 advise.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
