Re: IH 350 utility PTO
Posted by Jim on October 13, 2001 at 10:51:16 from (198.247.178.197):
In Reply to: IH 350 utility PTO posted by brian on October 13, 2001 at 08:52:08:
On the top of the PTO there is a small cover, take it off and you will see two screws, Make sure the PTO lever is in the middle position, loosen the lock nut and turn the screw in until the front side of the lock on the lever is lined up with front side of slot on the PTO.
Post A Followup
: Re: Re: IH 350 utility PTO
