Re: super c 12 volt conversion
Posted by Haas on October 13, 2001 at 17:40:16 from (129.37.117.132):
In Reply to: super c 12 volt conversion posted by Vaughn Gongaware on October 13, 2001 at 09:34:32:
If the tractor has a battery ignition, you will need a resistor for the coil circuit. You will need to change the lights to 12 volt. You will need a 12 volt one wire alternator and maybe a bracket to mount it. Go to a Starter/Generator repair shop. The one I use has everything you need to make the conversion, including the brackets and rebuilt alternators. Make sure you get the smallest pulley possible on the alternator or you will have trouble getting it to turn fast enough to charge.
Post A Followup
: Re: Re: super c 12 volt conversion
