Re: Transmission fluid for Farmall 450
Posted by TP from Central PA on October 13, 2001 at 17:47:15 from (64.12.107.47):
In Reply to: Transmission fluid for Farmall 450 posted by BEL on October 13, 2001 at 16:11:37:
I have used Hy-Tran in our red ones, but I have heard 80/90 wt gear lube helps stop gear movement faster- easing the gear grinding. I have never tried this but I know it does make sense and our gears do grind alot when shifting, just have to hold in the clutch a little longer!
Those 281's in a 450 produce alot of torque, gear oil also might give more protection in the rear end as well!
Post A Followup
: Re: Re: Transmission fluid for Farmall 450
