Re: fan assymbly for a super C
Posted by J3nut on October 14, 2001 at 14:54:41 from (205.188.197.183):
In Reply to: fan assymbly for a super C posted by waterpirate on October 14, 2001 at 13:36:07:
You might just need to add oil to the fan hub.
To do this you turn the screw to the side and remove. Fill with oil till it starts to run out a little. Then turn the screw hole down. There is a standpipe inside that will allow any excess to run out. Replace the screw and you are ready to go.
Before I read the directions in the manual I overfilled mine but if you follow the above you may be in good shape without replacing the one you have.
Good luck.
Mark
Post A Followup
: Re: Re: fan assymbly for a super C
