Re: Re: Super C Air Cleaner
Posted by Andy Martin on October 15, 2001 at 07:13:36 from (63.25.216.134):
In Reply to: Re: Super C Air Cleaner posted by Garidgerunner on October 15, 2001 at 06:33:27:
The 10 hr recommendation is proper but is for hard use under dusty conditions. The oil bath air cleaners are very high efficiency. When you dump the old oil out be sure to clean the dirt left in the bottom. As long as the dirt has not built up over 1/4 inch in the bottom of the cup (some say 1/2 inch) the air cleaner has been cleaned soon enough. Tractors used on grass and pavement need their air cleaner cups cleaned spring and fall to get moisture out of the oil. Disking in dusty conditions (where you cannot see the tractor hood on the down wind pass around the field) you barely get 1/4 inch buildup in a 10 hr day. Your nose gets more buildup than the air cleaner. Manufacturers went to paper air filters to save money, not for improved efficiency although the paper filters WHEN CLEAN have a little less restriction. Old timers used used oil for air cleaners. It is not recommended. I use drip oil collected from "empty" oil cans of all types: motor oil, hydraulic fluid, ATF, gear oil, etc.
Home
| Forums
Today's Featured Article -
Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
